nokia Digitalreceiver Satellitenreceiver  dbox2 sat
Serverzeit: 31 12 2025  08:05:11      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Digitalreceiver nokia dbox2 sat
BID = 479770
metropar
Hersteller : nokia
Gerätetyp : dbox2 sat
Chassis : 2x intel avia 600
nokia dbox2 sat display empty and burns weak
also no power on + cs36 100uf 25v (cs 36 its oke}
check diode and elko s seems oke
when follow layer going to ls14 also no power on layer
gr metropar
BID = 479785
Varaktor
Hello,
check power units and related stuff as well
as your posted info text suggests!
Groetjes ,
Varaktor
(sorry cannot respond in ur language ;-))
BID = 479874
Satfan123
Sat- und DBox-Spezialist
look likes bootloader or cpu
BID = 479969
metropar
hi satfan
yes i thinking also bad
the strange thing its that i dont have power on cs 36 witch its connect to lm 393
i have 3,3 volt 5 volt 12v 24 volt
bad on cs 36 25v 100uf i have 0 volts
where to find a bootsoft for this box?
so i cant take out te flash and put new boot into
is there schematic avv. for this reciever?
gr metropar
BID = 480131
Satfan123
shematic see www.
take out the flash and programm it with original loader
BID = 480419
metropar
thanks
witch flash contains bootloader the 1H2 cq 1H5 ??
witch boot you are toking bmon 1,2??
dondt have find schematic /boot on the www yet bad keep searcing
gr metropar
BID = 480487
Satfan123
bootloader is splitted in both flash
gerechnet auf die letzten 30 Tage haben wir 16 Beiträge im Durchschnitt pro Tag       heute wurden bisher 2 Beiträge verfasst
© x sparkkelsputz        Besucher : 188012816   Heute : 1402    Gestern : 7121    Online : 263        31.12.2025    8:05
